Warning message
RADIUS backuping
Nov 3rd, 2005
I have cisco 5350 with voip users, cisco using radius server to sevice voip users. Is it posible to use two radius server - if the first server fail then all accounting records will sand to another one ?
Georg Pauwen Fri, 11/04/2005 - 22:42
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
You can use multiple 'radius-server host' or 'tacacs-server host' commands to specify multiple hosts. The software searches for hosts in the order you specify them.
Example:
radius-server host RADIUS1
radius-server host RADIUS2
If RADIUS1 is down, RADIUS2 will be contacted. The same for TACACS:
tacacs-server host TACACS1
tacacs-server host TACACS2
If TACACS1 is down, TACACS2 will be contacted. Of course if RADIUS1 or TACACS1 reject the request, RADIUS2 or TACACS2 will not be contacted.
HTH,
GP
