BGP route map question
Nov 3rd, 2005
I came across a route-map statement on the config. of router A peering through EBGP to router B.
neighbor <router B's IP> route-map
PREF in
route-map PREF permit 10
match community 10
set local-preference 110
route-map PREF permit 20
match community 20
set local-preference 120
route-map PREF permit 30
My question concerns the need for the last permit statement. What is the default action in route maps when no match and/or set actions are specified?
Rajesh
rwiesmann Thu, 11/03/2005 - 06:37
  • Bronze, 100 points or more
the third statement will assign a local pref of 100 (default) to all prefixes which will not have a community set to 10 or 20.
Default local pref see:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080094431.shtml
If you do not have the last permit statement it would simply ignore all prefixes without a community of either 10 or 20.
Hope that helps
Roger
rajesh444 Thu, 11/03/2005 - 07:36
Roger,
Thanks. Without the last permit statement, would
all other prefixes be dropped or simply ignored and
passed through?
Assuming router A is running IBGP with other
routers in its AS, wouldn't it advertise EBGP
learned prefixes to IBGP peers with default
local-pref value of 100 anyway?
Rajesh
rwiesmann Thu, 11/03/2005 - 07:50
Hi Rajesh,
without the last permit statement the prefixes will be ignored/dropped and not passed through.
so in the sample you give the answer is no....the router would not accept it and because of this not advertise this prefixes.
regards
roger
