Warning message
Webserver on VMS server stops working
Nov 4th, 2005
Folks,
I just deployed VMS with the latest release and service pack level. I am unable to see the event viewer of IDS MC as it complains about apache not working correctly, is it a BUG? or may be my log files are too big??
If i reboot the VMS server, everything is alright for a couple of hours, but then we are back to square one.
ssoberlik Thu, 11/10/2005 - 09:19
  • Bronze, 100 points or more
proper coexistence of SIMS 3.1 with Cisco VPN/Security Management Solution (VMS) running on Internet Explorer 6.0, you must make the following change to the Internet Explorer settings:
Step 1 Open Internet Explorer.
Step 2 Select Tools > Internet Options > Advanced.
Step 3 Under Java (Sun) area, deselect "Use Java 2 v1.4.1_2 for (requires restart)," then click Apply.
Step 4 Restart CiscoWorks.
Step 5 Open the SIMS desktop in a new browser.
