Warning message
Rate Limit Internet Bandwidth
Nov 7th, 2005
I was wondering if there is a way to limit bandwidth on a 2950G without having to configure QOS. Here's what I want to do. I have 1 2950G connected to 4 network devices. 3 of these devices connect to networks that share the internet connection on the other (4th) port. I want to assign one port 1MB max, another port 2MB max and the 3rd port the rest of the bandwidth (it's a 10MB circuit). What's the best way to configure this without having to go thru the hassle of configuring QOS? If I have to configure QOS, any configuration guidance would be appreciated. Thanks.
spremkumar Tue, 11/08/2005 - 01:46
  • Red, 2250 points or more
AFAIK you can make use of class-based policing and police your traffic accordingly.
If the policed traffic exceeds the configured limit then you can configure drop policy for the same traffic flow.
These features are supported in 12.1(22)EA5 ios code .
for more info would suggest to check this link out if you havent seen the same earlier.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat2950/12122ea5/2950scg/swqos.htm
regds
