Warning message
resurrection of Catalyst 3500 seriesXL
Nov 7th, 2005
Hi! I got not working Catalyst 3500 seriesXL with so symptoms:
After powering on "system", "rps" and "speed" leds are glowing. Leds of ports with numbers 6, 10, 14, 18, 22 are glowing too.
Console port doesn't send any information... What can I do to brighten device?
PS
Step by step like:
- Unplug the power cord.
- Hold down the MODE button located on the left side of the front panel, while reconnecting the power cable to the switch
- Release the MODE button after the STAT LED goes out. You should be at the switch: prompt.
Doesn't work... Console still shows nothing, but "system", "rps" and "speed" leds stop glowing
thomas.chen Fri, 11/11/2005 - 07:11
  • Silver, 250 points or more
You are saying that those rps, System and speed led's are glowing.Which color led's are on.Green or Amber?let me know regarding this.I think the following URL will be helpful for u to diagonise and solve the problem.Because, it contains a detailed description of the switch front panel.
http://www.cisco.com/en/US/products/hw/switches/ps637/products_installation_guide_chapter09186a008007d26e.html
