Warning message
access list issues
Nov 7th, 2005
I am running a 3005 behind a router with a T1 WIC. My syslog box is showing traffic being denied by the acl, although I thought I had it setup to allow any traffic to 66.89.100.69. The external of the 3005 is 66.89.100.69 which is being natted to 10.236.47.230
Below is my config.
interface Loopback0
ip address 66.89.110.65 255.255.255.248
interface Ethernet0/0
no ip address
interface Ethernet0/0.10
encapsulation dot1Q 10
ip address 10.236.47.253 255.255.240.0
ip nat inside
interface Ethernet0/0.20
encapsulation dot1Q 20
ip address 10.236.63.240 255.255.240.0
ip nat inside
interface Serial0/0
bandwidth 1544
ip address 67.106.46.14 255.255.255.252
ip access-group sdm_s0/0_in in
ip nat outside
encapsulation ppp
service-module t1 timeslots 1-24
interface Ethernet0/1
ip address 10.0.3.240 255.255.255.0 secondary
ip address 10.0.9.240 255.255.255.0
ip nat inside
shutdown
ip nat inside source static 10.236.47.230 66.89.100.69
ip nat inside source static 10.236.48.10 66.89.110.67
ip access-list extended sdm_s0/0_in
permit tcp any eq 5080 host 10.0.1.75 log
permit tcp any eq 5080 host 66.89.110.67 log
permit tcp any eq 1099 host 66.89.110.67 log
permit tcp any eq 1099 host 10.0.1.75 log
permit ip host 161.165.202.24 any log
permit ip host 161.165.202.26 any log
permit ip host 161.165.202.28 any log
permit ip host 161.165.202.25 any log
permit ip host 161.165.202.27 any log
permit ip host 161.165.202.29 any log
permit tcp any host 10.236.47.230 log
permit ip any host 10.236.47.230 log
permit udp any host 10.236.47.230 log
permit ip any host 66.89.100.69 log
permit tcp any host 66.89.100.69 log
permit udp any host 66.89.100.69 log
deny ip any any log
deny tcp any any log
logging facility auth
logging source-interface Ethernet0/0.10
logging 10.252.1.31
access-list 1 permit any
Richard Burts Mon, 11/07/2005 - 13:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Adam
It certainly looks to me like the access list should permit traffic to the address since there are permit ip any host that include both its inside and outside format.
The good news is that the deny statements include the log option. So there should be log messages which show information about what is denied. If you would post some of these log messages we might be able to find what is causing them to be denied.
Rick
