Add digits
Nov 8th, 2005
I am using an MGCP gateway . when an external call comes in I want to be able to add 90 on to the number so it will display as 90XXXXXXXX on the called numbers phone.
hi jamjam,
Instead of pointing your gateway's "Incoming calls Calling search space" to a CSS with your phones in, add a dummy partition and css only for the purpose of adding those digits e.g. CSS_INCOMINGCALLS & PAR_INCOMINGCALLS.
In this new partition, add a traslation pattern that will match all calls, and add 90 to the "Calling Party Prefix digits" parameter. And select the css with your phones in as the Calling search space.
Peter
jamjam200 Tue, 11/08/2005 - 03:48
great thanks. the translation pattern to match all calls is it just blank?
Aaron Harrison Tue, 11/08/2005 - 04:05
  • Community Spotlight Award,
    Member's Choice, May 2015
You could use the callmanager service parameter 'national number prefix' or 'international number prefix' under the MGCP section to prefix the digits without going through setting up CSSs etc..
Aaron
