Warning message
trunk and channel problem
Nov 8th, 2005
i have 2 4507s each with dual sup 4s. I have applied the below configs to them respectively. However, the interfaces both show down and down, any suggestions?
interface Port-channel1
description Connecting both buildings
switchport
switchport mode trunk
interface GigabitEthernet1/1
description Connection to building-1
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet2/1
(2nd Switch)
switchport
description Connection to building-2
interface GigabitEthernet 2/1
lgijssel Tue, 11/08/2005 - 08:25
  • Red, 2250 points or more
Looked up the document describing how to do this:
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a00804d7817.html#wp1020670
It doesn't look as if you did something wrong but with a partial config that is hard to see;-)
Please follow the guidelines for troubleshooting as depicted. Hope this helps you a bit further.
Leo
bkaren1278 Tue, 11/08/2005 - 08:31
this document shows giving the port channel an IP, is this necessary, also i need to make sure all vlans go across this trunk..
lgijssel Tue, 11/08/2005 - 09:43
I noticed in your configs that there is a difference between both supervisors. The channel is configured on one module, shut on the otehr one. This may point to a redundancy issue. Looked up a URL on that as well:
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_configuration_guide_chapter09186a00804d781c.html#wp1113491
Suggest that you check this first and bring your sup4's back in sunc if needed.
Leo
bkaren1278 Tue, 11/08/2005 - 09:51
can you please elaborate on this. i do notice that i cannot console through both sups and sometimes when i reload it switches which ones i can console into
glen.grant Tue, 11/08/2005 - 09:46
  • Purple, 4500 points or more
The config looks pretty much ok. The other question is do you have link lights between the 2 switches on both ends ? At the very least you should have the physical layer stuff active . Running crossover cables between them ?
