Warning message
NAT TCP translation timout
Nov 8th, 2005
Hi All,
Can anybody explain to me why the NAT TCP translation timeout default is 86400 seconds (1 day). I am running NAT overload and most of the time my NAT space gets filled over with lot of translations. I want to know the appropriate TCP fine tuning in this regard.
Praful
cisco2003 Tue, 11/08/2005 - 16:22
Hi Praful,
I think you have many P2P application, like BT, EDonkey etc. Each NAT entry uses around 20 bytes of memory, router would run out os memory if sessions burst out in a high volume. So you need limit the nat entry number on router, try:
ip nat translation tcp-timeout 60
ip nat translation max-entries 70
You can tune tcp-timeout and max-entries smaller until it works fine.
