Warning message
Question : "Proposed status" using show isdn service
Nov 8th, 2005
Hello.
I have a problem with my voice gateway.(c2851 with 12.3(11)8T)
We have two isdn pri line between two pods. Pod-A have one gateway with two pri line, Pod-B have two gatway, each gateway connect just one isdn pri line.
Today, Pod-B's gateway have problem.
At that time, I tried to retrieved the status of the isdn, the output dispayed "proposed" by using show isdn service.
But i don't the mean, that is "Proposed".
Could you please tell me the status?
reagrds,
John.
gateway#sh isdn service
PRI Channel Statistics:
ISDN Se1/0:15, Channel [1-31]
Configured Isdn Interface (dsl) 0
Channel State (0=Idle 1=Proposed 2=Busy 3=Reserved 4=Restart 5=Maint_Pend)
Channel : 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1 2 3 4 5 6 7 8 9 0 1
State : 1 1 1 1 1 2 2 1 1 0 0 0 1 1 0 3 1 0 1 0 1 1 0 0 1 1 1 1 1 1 1
Service State (0=Inservice 1=Maint 2=Outofservice 8=MaintPend 9=OOSPend)
State : 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
Nov 9 11:22:57.777 KST: %ISDN-6-CHAN_UNAVAILABLE: Interface Se1/0:15 Requested Channel 1 is not available
Nov 9 11:22:57.781 KST: ISDN Se1/0:15 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x808C
Cause i = 0x82AC18 - Requested circuit/channel not available
ebreniz Mon, 11/14/2005 - 14:06
  • Silver, 250 points or more
Did you reconfigure the PRI lines or do a restart of the routers. does that resolves the issue.
Check for the bug CSCee11391in the bug tool kit. Need to upgrade to another version.
Santi Cuni Thu, 01/25/2007 - 00:00
Hello
I have your same problem "Requested circuit/channel not available" but I can't see if there is a bug about this problem or not. Could you tell me if this problem is a bug and from which IOS this caveates is will fix? Also could you tell me please which device are interested?
Thanks in advance
