Warning message
PIX 520 to PIX 520 IPSEC TUNNEL IOS 6.3(4)
Nov 9th, 2005
We have two cisco PIX 520 16M FLASH IOS 6.3(4) on both and 2 FE interfaces on each firewall. (Identical PIXes)
The first PIX CONFIG is:
nameif ethernet0 outside security0
nameif ethernet1 inside security100
access-list 101 permit ip 192.168.XXX.0 255.255.255.0 192.168.AAA.0 255.255.255.0
access-list 102 permit ip 192.168.XXX.0 255.255.255.0 192.168.AAA.0 255.255.255.0
nat (inside) 0 access-list 101
crypto ipsec transform-set SecuritySet esp-des esp-sha-hmac
crypto map rtpmap 1 ipsec-isakmp
crypto map rtpmap 1 match address 102
crypto map rtpmap 1 set peer AAA.AAA.AAA.AAA
crypto map rtpmap 1 set transform-set SecuritySet
crypto map rtpmap 1 set security-association lifetime seconds 3600 kilobytes 4608000
crypto map rtpmap interface outside
isakmp enable outside
isakmp key ******** address AAA.AAA.AAA.AAA netmask 255.255.255.255
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption des
isakmp policy 1 hash sha
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
And the second PIX Config is:
access-list 101 permit ip 192.168.AAA.0 255.255.255.0 192.168.XXX.0 255.255.255.0
access-list 102 permit ip 192.168.AAA.0 255.255.255.0 192.168.XXX.0 255.255.255.0
crypto map rtpmap 1 set peer XXX.XXX.XXX.XXX
isakmp key ******** address XXX.XXX.XXX.XXX netmask 255.255.255.255
We have turned logging on and debugging for IPSEC and ISAKMP, but threr seems to be no connection attempts between the two PIXes none of the PIXes is trying to initiate a connection to the other PIX.
Please Help!
