Warning message
Unity Exchange and SQL patches
Nov 10th, 2005
can we get the same patches for exchange server and sql server for unity from MS directly instead of from cisco website, I know I can get from cisco website, but for some reason , we need to get it from MS side, are thoes the same ? can we do that ? thanks
Ginger Dillon Thu, 11/10/2005 - 07:43
  • Blue, 1500 points or more
Hi -
For Unity yes. I've pulled software updates from Cisco or Microsoft's web sites for service packs, security updates etc. for the Unity servers. I do check with Cisco and the forum just in case there's an alert on a hotfix or an update required for a service pack (permissions wizard update for example). Microsoft updates are not applicable for CallManager servers though. These must be obtained from Cisco directly.
Ginger
