Warning message
ACS 3.0 strange failed attempts
Nov 10th, 2005
I am currenlty using Cisco ACS 3.0 and have noticed very strange logs under Reports,failed Attempts.
It is showing numerous failed attempts from username : azbycx to our 4 Core 6500 Catos Switches.
The caller-id field does not display a source ip address and these hits are happening every minute.
I have noticed that any passed or failed attempts to any catos switches does not provide a caller-id ip address in the report. Any ios attempts logs the ip address fine.
Any help would be appreciated. Even a way to log the catos switch to determine what is attempting to log into these 6500 switches.
Thanks SG
darpotter Fri, 11/11/2005 - 07:54
  • Silver, 250 points or more
Is your concern that
a) the switch is the problem, or
b) that acs isnt logging correctly
You can easily check what acs is recieving
Run CSradius -z -p or CSTacacs -z -e at the command line to see a packet-by-packet debug.
simon-galloway Sun, 11/13/2005 - 18:24
I ran the csradius -z -p and got the following debug results on unknown username "azbycx"
I not sure if this debug is telling me anything l don't already know !!!
Also caller-id from the failed attempts report is not showing a source ip address from the switches in question which are running CATOS ??
Request from host 172.16.2.6:1645 code=1, id=69, length=65 on port 1024
[001] User-Name value: azbycx
[004] NAS-IP-Address value: 172.16.2.6
[079] EAP-Message value: .E...azbycx
[080] Message-Authenticator value: F2 F3 E3 1C 56 E9 73 10 14 DE C6 F7 24 31 5F 29
ExtensionPoint: Initiating scan of configured extension points...
ExtensionPoint: Calling [AuthenticationExtension] for Supplier [Cisco Generic EAP]
ExtensionPoint: [Generic EAP] ASAuthenticateUser failed [-1092]
ExtensionPoint: [GenericEAP.dll->AuthenticationExtension] returned [3 - reject]
ExtensionPoint: Start of Attribute Set
ExtensionPoint: End of Attribute Set
User:azbycx - Authentication type not supported by external database
Sending response code 3, id 69 to 172.16.2.6 on port 1024
Request from host 172.16.2.8:1645 code=1, id=164, length=65 on port 1024
[004] NAS-IP-Address value: 172.16.2.8
[079] EAP-Message value: .¤...azbycx
[080] Message-Authenticator value: FD B9 66 FE A4 50 57 FE 68 1F B3 2A CE 57 2C 63
Thanks for your assistance
darpotter Mon, 11/14/2005 - 00:39
Hmm, your switch is trying to perform an EAP authentication - albeit not very well since there are no calling/called station id attrs which are normal with .1x
I suspect the catos debug logs may give you more of an idea, because this doesnt look like an ACS issue.
Sorry I cant help more
simon-galloway Mon, 11/14/2005 - 15:16
Thanks for the reply.
Do you know exactly what debug logs l need to activate on the 6500 CATOS to determine where this source authentications are coming from ??
E.g Radius logging
I was testing 802.1x authentication and ran into this issue. Here's the TAC response I recieved and this fixed the problem:
Just for the future reference we were getting this issue because the keep alives packets are sometimes missinterpretted by ACS server so by adding "Set dot1x radius-keeplive disable" the command stops those keep-alive packets.
