Warning message
ankurbhasin Thu, 11/10/2005 - 23:47
  • Red, 2250 points or more
Hi Frined,
You can enable "ip accounting" when it is highly utilized and after sometime just run the command "sh ip accounting" to get the toptalkers.
Ankur
olorunloba Fri, 11/11/2005 - 01:47
  • Silver, 250 points or more
Enabing netfow is often helpful also. Configure ip route-cache flow on the interfaces, and use show ip cache flow to see the result.
Netflow gives more information, such as source and destinaton ip address, soruce and destination ports, ip protocol type and number of packets in active flow.
