Warning message
Network Delay
Iam using Cisco Pix 501. Whenever i use network commands it get some delay in response. For example if I connect to network drive using net use command i get 4/5 second delay then the commands executes. Or if i open my maped drived it get some delay & then the drive opens. Is there any specific reason why we get these delay?
Iam connecting firewall directly to my network which uses DNS for name query. Ours is pure IP network with windows 2003 server DHCP/DNS/Domain Controller. All the switches, routers, Network cards are on Gagabit capacity. Below is the configuration of my firewall:
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxx encrypted
passwd xxxxxxx encrypted
hostname pixfirewall
domain-name testing.edu
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.129 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxxx
: end
jackko Sat, 11/12/2005 - 15:42
  • Gold, 750 points or more
according to the posted config, there is no lan-lan vpn or remote vpn access, so i am assuming the traffic you are having issue with is within the pix inside net.
if so, then pix is pretty much out of the picture. the reason being traffic within the same net will not be processed by the pix at all.
e.g a pc (192.168.1.100) is initiating a drive mapping with a server (192.168.1.200). firstly, the pc will send an arp request in order to obtain the server mac address. once the mac address of the server is avaliable, the pc will then forward the packet directly to the server.
jackko Sun, 11/13/2005 - 14:06
the issue may be related to the pix outside interface speed and duplex.
do "sh int" to identify the current speed and duplex. i believe by applying the keyword auto, it would yield 10 half only, which may not be compatible to the gigabit devices.
e.g.
pix# sh int
interface ethernet0 "outside" is up, line protocol is up
Hardware is ixxxx9 ethernet, address is xxxx.xxxx.e285
IP address xxx.xxx.xxx.101, subnet mask 255.255.255.255
MTU 1492 bytes, BW 10000 Kbit half duplex
pix# conf t
pix(config)# int e0 100f
pix(config)# sh int
MTU 1492 bytes, BW 100000 Kbit full duplex
jackko Tue, 11/15/2005 - 14:53
i was just reading another conversation, and the netpro suggested that the command "sysopt noproxyarp " may resolve odd connectivity issue.
