Warning message
Cat3560G Port Numbering Scheme
Nov 13th, 2005
I can't seem to find such trivial info as port numbering scheme on the 3560G-24 and 3560G-48 anywhere. Does anyone know the port numbers for the 4 SFP ports on these two 3560G models?
Thanks.
thisisshanky Sun, 11/13/2005 - 22:04
  • Purple, 4500 points or more
I would think those are labelled gi 0/1, 2 3 and 4.
Since these switches are not stacakable like 3750s, they should not follow the slot/module/port format.(for ex: 1/0/1 etc).
michael.l.choo@... Sun, 11/13/2005 - 22:10
Thanks. Yes, I'm quite aware that they does not follow the 3750 numbering scheme. What I was not sure about was whether the SFPs "share ASICs" with the copper ports.
Based on your response, should I then presume that we can only use EITHER the SFPs OR the first 4 copper ports?
Thanks.
