Warning message
Two different public ip addresses NAT'd to the same inside address?
Nov 14th, 2005
I am trying to find a way to have 2 different public ip's go to the same interface on a pix. BGP is not an option. The networks are from two completely seperate providers. I am just curious to know if i could do what is in the example below.
2801:
ip nat inside source static 10.10.10.1 2.2.3.1 extendable
ip nat inside source static 10.10.10.1 1.1.2.1 extendable
int fa0/1
description ***** Connection to pix 501 *****
ip address 10.10.10.1 255.255.255.252
PIX 501:
description ***** Connection to 2801 fa0/1 *****
ip address outside 10.10.10.2 255.255.255.252
spremkumar Mon, 11/14/2005 - 23:31
  • Red, 2250 points or more
Can u revert whether you are connecting to 2 ISPs for reduandcy kidna purpose of load balancing ??
regds
jeffdanderson Tue, 11/15/2005 - 08:21
I am looking for a reduandancy solution. Inbound load-balancing isnt so important, just want a way to reach the pix using either t1 for access incase one of the T1 goes down. Maybe setup a round-robin dns for both ip addresses and setup the vpn client with a hostname instead of an ip address.
Looking for any solution that doesnt require BGP or more hardware.
