Warning message
X.25 SVC's rejected - international link busy
Answered Question
Nov 16th, 2005
I have the following problem: multiple simultaneous connections (SVC's) get rejected by the router, usually after the 4th LCI has been established.
I'm using a Cisco 2500 router, with IOS Enterprise 12.
Do you know the solution to this problem (the debug error message is (Cause 0, Diag 116 (DTE originated/International link busy)) ?
Thanks very much.
[email protected]
Correct Answer by smalkeric about 11 years 9 months ago
There may be a few reasons for this.So, to further trace it through, i want u to send me the following debugs :
deb pad
deb x25 eve
debug translation
A factfile reason for this problem is the router not allowing many no of TCP sessions.If this is the case,then change the line vty cmd values.
Overall Rating: 5 (1 ratings)
Correct Answer
smalkeric Tue, 11/22/2005 - 07:43
  • Silver, 250 points or more
deb pad
deb x25 eve
debug translation
nceitil Wed, 12/21/2005 - 00:53
Hi Sam,
Sounds like you know a little about X25.
Would you mind having a look at my post (X25 HELP - posted 21-12-05).
