Bundle L2 EOMPLS VPN
Nov 16th, 2005
i Need to bundle to two links & pass L2 trafficon 7609 router.can anyone suggest how to configure.
.let me if I need to configure etherchannel/multilink or any other way is their for bundaling link.
regards,
AnandJalawadi Wed, 11/16/2005 - 23:25
yes u can bundle the baove said links using mlfr concept to pass on l2traffic.
Let me know this really helps.
Anand
moorthy1977 Thu, 11/17/2005 - 00:36
Can you please guide me how to configure it with commands
attrgautam Thu, 11/17/2005 - 02:50
  • Silver, 250 points or more
Are your links going to act CPE Links or Core links. You can do Port channel, MFR for bundling. MLPPP is not a good soln for Multilink.
For etherchannel
http://www.cisco.com/en/US/products/hw/routers/ps368/products_configuration_guide_chapter09186a0080160eb8.html
For MFR
http://www.cisco.com/en/US/products/hw/routers/ps368/products_configuration_guide_chapter09186a00803f37a8.html
romccallum Thu, 11/17/2005 - 07:16
i believe what you are asking is can you take two ethernet ports and then portchannel them and then Eompls on that port channel. The answer to that is no you cant do that.
attrgautam Thu, 11/17/2005 - 20:38
I just checked in the 7600 12.2(18) SXF tells me it supports EoMPLS on the core and edge. Is there any link which says it doesnt support ? Please let me know
Interface Port-channel1
Transport type Eth VLAN
Core functionality:
MPLS label disposition supported
Distributed processing supported
Control word processing supported
Sequence number processing not supported
VCCV Type 1 processing not supported
Edge functionality:
MPLS label imposition supported
Control word processing not supported
Transport type Ethernet
Core functionality:
Edge functionality:
moorthy1977 Fri, 11/18/2005 - 02:35
I need to connect two ports on 7609 for EOMPLS network.In short i need to give 400 mpbs connectivity over fast ethernet due to gigbit port problem.I will connect four fastethernet cable from router A to MPLS PE(A) Router then PE(B) Router will connect to router B thurogh four fastethernet cable.
Well through cisco 6509 switch i can use port channel or multilink but i require connectivity for L2 MPLS.
Please suggest best possible solution.
attrgautam Fri, 11/18/2005 - 20:05
You can do port channel and see if it works. or u can create 4 different pseudowires from the interfaces and probably do load-balancing over them which would also solve your issue
