thisisshanky Wed, 11/16/2005 - 21:26
  • Purple, 4500 points or more
Are these links terminated on same router ? Between ISP A and ISP B, if ISP A is the preferred route, all routes from ISP A should be installed (those in common with ISP B).
Once you enable maximum path command, you should see two next hops for each prefix from ISPA.
To prefer ISP A over ISP B, you can set a route-map with a higher weight specified for ISP A.
PS: Please rate the post if it helped you!
umar-rana Wed, 11/16/2005 - 22:55
Yes, all the links are on the single link. Both links of ISP-A needs to be utilized at the same time and ISP-B can work as backup.
