Igrp And Ospf And Rip And Sending Packet Out ?
Nov 16th, 2005
If I have got a scenario asking me not to send EIGRP packets out any other interfaces except interface Ethernet 0/0 (ip address is 183.1.123.3),,,,,,,,,,,then I can configure the router like this:
Router eigrp 100
Network 183.1.123.3 0.0.0.0------ ip address for fa 0/0,,,not the whole network.
I can this for OSPf as well.
Can I use same procedure with RIP ?
Second question:
For OSPF we choose router-id , why do we need to configure this for EIGRP or IGRP
amit-singh Wed, 11/16/2005 - 22:46
  • Blue, 1500 points or more
Router eigrp 100
With this command, OSPF and EIGRP works only on that interface not any other interface.
In case of RIP, its not possible. You have to use " passive interface " command in order to stop the RIP packets.
in case of EIGRP, router -id is used to identify the originating router for external routes. If an external route is received with the local router ID, the route is discarded. The router ID can be configured with any IP address with two exceptions; 0.0.0.0 and 255.255.255.255 are not legal values and cannot be entered. A unique value should be configured for each router.
HTH,
-amit singh
zillah2004 Thu, 11/17/2005 - 02:37
Thanks Amit
"If an external route is received with the local router ID, the route is discarded. "
Could you please explain the above more ?
mheusinger Thu, 12/15/2005 - 10:35
  • Green, 3000 points or more
a router will not accept a route which it assumes inserted it into EIGRP itself. This is concluded from the router ID in an update. Its a basic measure to avoid possible routing loops.
hope this helps
Martin
P.S: please rate any post you find helpful.
