Warning message
outgoing FTP problem
Nov 16th, 2005
Can somebody help me why my outgoing ftp connection doesn't work. below is my pix firewall config:
PIX# show runn
: Saved
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password
passwd
hostname PIXxxx
domain-name xxxx.xxx
no fixup protocol dns
fixup protocol ftp strict 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list inbound permit tcp any any eq ftp-data
access-list inbound permit tcp any any eq ssh
access-list inbound permit tcp any any eq smtp
access-list inbound permit tcp any any eq telnet
access-list inbound permit tcp any any eq domain
access-list inbound permit tcp any any eq www
access-list inbound permit tcp any any eq 8080
access-list inbound permit esp any any
access-list inbound permit ah any any
access-list inbound permit gre any any
access-list inbound permit icmp any host x.x.x.x
access-list inbound permit udp any any eq 1701
access-list inbound permit icmp any any
access-list inbound permit tcp any any eq 3389
access-list inbound permit tcp any any eq 8000
access-list outbound permit tcp any any eq ftp
access-list outbound permit tcp any any eq ftp-data
access-list outbound permit tcp any any eq 8080
access-list outbound permit udp any any eq 10000
access-list outbound permit udp any any eq 4500
access-list outbound permit udp any any eq isakmp
access-list outbound permit tcp any any eq 8000
access-list outbound permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside x.x.x.x x.x.x.x
ip address inside x.x.x.x 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
pdm history enable
arp timeout 14400
global (outside) 1 x.x.x.x
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) x.x.x.x a.a.a.a netmask 255.255.255.255 0 0
access-group inbound in interface outside
access-group outbound in interface inside
router ospf 32
network x.x.x.x 255.255.255.0 area 1
log-adj-changes
route outside 0.0.0.0 0.0.0.0 x.x.x.x 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
snmp-server location xxx
snmp-server contact xx
snmp-server community xxxx
no snmp-server enable traps
floodguard enable
service resetinbound
service resetoutside
telnet x.x.x.x 255.255.255.0 inside
telnet timeout 15
ssh x.x.x.x x.x.x.x outside
ssh timeout 60
console timeout 0
terminal width 80
Cryptochecksum:xxxx
: end
alcher Thu, 11/17/2005 - 02:05
I remove the "strict" at fix protocol ftp, but no positive out. my outgoing ftp still not working.
by the way, I do use this wise-ftp and cuteftp as my ftp client.
alcher Thu, 11/17/2005 - 02:17
below is the sample output from cuteftp:
STATUS:> Getting listing "/pub/redhat/linux"...
STATUS:> Resolving host name ftp.redhat.com...
STATUS:> Host name ftp.redhat.com resolved: ip = 209.132.176.30.
STATUS:> Connecting to ftp server ftp.redhat.com:21 (ip = 209.132.176.30)...
STATUS:> Socket connected. Waiting for welcome message...
220 Red Hat FTP server ready. All transfers are logged. (FTP) [no EPSV]
STATUS:> Connected. Authenticating...
COMMAND:> USER anonymous
331 Please specify the password.
COMMAND:> PASS *****
230 Login successful.
STATUS:> Login successful.
COMMAND:> PWD
257 "/"
STATUS:> Home directory: /
COMMAND:> FEAT
211-Features:
EPRT
EPSV
MDTM
PASV
REST STREAM
SIZE
TVFS
211 End
STATUS:> This site supports features.
STATUS:> This site supports SIZE.
STATUS:> This site can resume broken downloads.
COMMAND:> REST 0
350 Restart position accepted (0).
COMMAND:> CWD /pub/redhat/linux
250 Directory successfully changed.
STATUS:> PWD skipped. Current dir: "/pub/redhat/linux".
COMMAND:> PASV
227 Entering Passive Mode (209,132,176,30,48,71)
COMMAND:> LIST
STATUS:> Connecting ftp data socket 209.132.176.30:12359...
ERROR:> Can't connect to remote server. Socket error = #10060.
425 Failed to establish connection.
421 Timeout.
em6557 Tue, 12/13/2005 - 17:30
Add this entry on your access list
access-list outbound permit tcp any any gt 1024
This should solve the problem connecting to passive ftp servers.
