Warning message
VG224/248 pinouts
Answered Question
Nov 17th, 2005
I am going to be installing a mixture of VG224s and VG248s in my building. What I am looking to do is run an amphenol cable to my old telco rooms so I can reuse existing cabling. I need to find out the pinouts from the VG so I can punch down to a 66 block for cross connects. Specifically, which of the pins are not used. Is it the last 2 of the 50 pin cable? I know this is probably a stupid question, I just need to verify so we can have cables run.
Jeremy
Correct Answer by Brandon Buffin about 11 years 9 months ago
Take a look at the following link. I believe it will give you what you need.
http://www.cisco.com/en/US/products/hw/switches/ps708/prod_installation_guide09186a00804197df.html#wp38398
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 5 (1 ratings)
