Netflow on 7600 with sup720 and interfaces in switchport trunk
I was wondering if there was a way to export netflow data from my Gigabit interfaces running in switchport trunk mode on my 7600 running in native ios mode with sup 720? I can see the Vlan information with the ip route-cache flow command, however, I see no similar command for the individual ports when configured with the switchport trunk command.
Jason
a-vazquez Wed, 11/23/2005 - 10:23
  • Silver, 250 points or more
think " ip flow-export source i/f no" command will solve u the problem.
To configure the Layer 3 interface used as the source of the NDE packets containing statistics from the MSFC2, perform this task:
Router(config)# ip flow-export source {{vlan vlan_ID} | {type1 slot/port} | {port-channel number} | {loopback number}} Configures the interface used as the source of the NDE packets containing statistics from the MSFC2:
Select an interface configured with an IP address.
Router(config)# no ip flow-export source Clears the NDE source interface configuration.
For more useful info, refer to the following link:
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7600/121_8aex/swcg/nde.htm
