Warning message
Line Appearance with No Ringing
Answered Question
Nov 17th, 2005
Is there a way on the CallManager 4.1.3 and or the 7960 to have a line appearance with no ringing. For example 1000(line1) will ring if dialed to from the outside or other extensions but 1001(line2) will not ring if dialed to, all on the same phone. I know the Nortel Meridian System can do this easily, unsure if MCS can.
Correct Answer by Brandon Buffin about 11 years 9 months ago
Yes, in DN configuration you can set the Ring Setting to Disable or Flash Only.
Hope this helps. If so, please rate the post.
Brandon
Overall Rating: 0 (3 ratings)
Correct Answer
Brandon Buffin Thu, 11/17/2005 - 11:51
  • Purple, 4500 points or more
Brandon
