Warning message
smalkeric Fri, 11/25/2005 - 12:21
  • Silver, 250 points or more
The Stateful Failover feature passes per-connection stateful information to the Standby unit. After a failover occurs, the same connection information is available at the new Active unit. End user applications are not required to do a reconnect to keep the same communication session. The state information passed to the Standby unit includes the global pool addresses and status, connection and translation information and status, the negotiated H.323 UDP ports, the port allocation bit map for PAT, and other details necessary to let the Standby unit take over processing if the Primary unit fails.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_v51/config/advanced.htm
