How to Forward (No Answer) to another user's mailbox?
Nov 21st, 2005
Greetings,
Using CME and CUE, I have three 7960 phones in a common shop area that all have a single line shared between them. How can I configure it so that the Forward No Answer sends the call to only one user's box?
Thank you.
adignan Mon, 11/21/2005 - 19:49
  • Blue, 1500 points or more
If these phones all share the same ephone-dn, then just forward no answer to the voicemail pilot and thats all you have to do
ephone-dn 1 dual-line
number 5000
description ShopSharedLine
name ShopSharedLine
call-forward busy 7000
call-forward noan 7000 timeout 10
ephone 1
mac-address 0000.0000.0000
type 7960
button 1:1
ephone 2
mac-address 0000.0000.0001
type 7960
button 1:1
ephone 3
mac-address 0000.0000.0002
type 7960
button 1:1
If they have different numbers, then on the VOIP dial-peer that sends calls to CUE, your config would look like this. DN's are 5000, 5001, and 5002. If you want all 3 to go to voicemail 5000.
voice translation-rule 1
rule 1 /5001/ /5000/
rule 2 /5002/ /5000/
voice translation-profile ChangeRedirectin
translate redirect-called 1
number 5000
description ShopSharedLine1
name ShopSharedLine1
ephone-dn 2 dual-line
number 5001
description ShopSharedLine2
name ShopSharedLine2
ephone-dn 3 dual-line
number 5002
description ShopSharedLine3
name ShopSharedLine3
ephone 1
type 7960
button 1:1
ephone 2
type 7960
button 1:2
ephone 3
type 7960
button 1:3
dial-peer voice 7000 voip
description CUE
translation-profile outgoing ChangeRedirecting
destination-pattern 7000
session protocol sipv2
session target ipv4:X.X.X.X
dtmf-relay sip-notify
codec g711ulaw
no vad
andy-berbee
malberttoo Mon, 11/21/2005 - 22:22
Wow, thanks for the speedy reply.
Each of the three phones has its own DID (987-3850, -3851, -3852), but the shared number is a published number that is not part of the 3800 DID block. Though all three instruments ring, only the shop manager's has voicemail enabled (well, set up anyways- I haven't actually figured out how to disable it from certain phones). It is his that I would like to respond.
ephone-dn 1
number 3850
name Shop Manager
call-forward busy 3801
call-forward noan 3801 timeout 15
ephone-dn 2
number 3851
name Shop Center
ephone-dn 3
number 3852
name Shop North
ephone-dn 4
number 9876543
label 987-6543
trunk 98 timeout 30
ephone1
type 7960
button 1:1 2:4
ephone2
type 7960
button 1:2 2:4
ephone3
type 7960
button 1:3 2:4
I'm quite a newb, so I very much appreciate your precise, detailed reply. I do not want the other two to go to voicemail at all, ever.
Thanks for your time.
