VMS 2.2
Nov 22nd, 2005
I have network connectivity between my sensor and my VMS work station.
When I tried to push a sig to my sensor, which is part of my sensor group, it won't see it....also the discover settings does not work either,
any help is appreciated.
b.hsu Mon, 11/28/2005 - 11:31
  • Silver, 250 points or more
Step 1 Insert the VMS Management and Monitoring Centers 2.2 (VMMC) Startup Disk CD into the CD-ROM drive, and then click Install on the Setup Program page that appears.
If the installation program does not start, select Start > Run from the Windows taskbar, and then enter d:\setup in the Run dialog box, where d is the drive letter of the CD-ROM drive. Press Enter to start the installation program.
The VMS Management and Monitoring Centers 2.2 page of the CiscoWorks InstallShield wizard lists all VMMC products and requests that you select the check boxes next to the products you want to install. There are also options to Select All and to Cancel installation.
Step 2 Select Management Center for IDS and/or Security Monitor to install IDS MC and/or Security Monitor. Deselect all other check boxes. Then, click Next.
The Ready to Install the Program page appears.
Step 3 Click Install to continue.
