Warning message
CM 4.x to CM 3.2 xfer to Unity Exp 2.1
Nov 22nd, 2005
  • Bronze, 100 points or more
OnNet Calls to and from CM to CME are working perfect (h323 & g729) the only issue is when a phone on the CME system rings out to Voice Mail (SIP) the call is dropped. Every thing appears fine users locally can check and divert to VM fine just with OnNet calls from external site.
Steven Smith Wed, 11/23/2005 - 05:57
  • Gold, 750 points or more
This sounds like a codec issue. CUE only does G711 and the calls are coming in G729. You can test this by using G711 from CM to CME.
heathrw Wed, 11/23/2005 - 13:41
We tried changed the OnNet Calls to G711 with the same result.. Sorry forgot to add that.
