Warning message
Bridging for a data connection
Nov 22nd, 2005
Now if I just have layer2 connectivity for LAN end to end.
Say LAN1-------WAN-------WAN-------LAN2
The connection is a bridge or layer2 which means no ip address is configured on the Wan. Then how can I access LAN2 from LAN1. Can ip address if connected as a layer2 for data connection have ip addresses
Overall Rating: 4 (1 ratings)
leonvd79 Wed, 11/23/2005 - 00:16
  • Silver, 250 points or more
That is very simple. You use the same network addressing scheme for both sites. Take care that networks do not overlap.
[192.168.0.0/24][R1]---/---[R2][192.168.0.0/24]
hosts 1 through 127 hosts 128 through 254
kunal-united Wed, 11/23/2005 - 02:06
Do you mean that we can configure ip addresses on the lan if there exist a data link connection from Lan to Lan.
That means ..
R1------------ BRIDGE --------------R2
| no ip on Wan Network |
IP:192.168.1.1/ 192.168.128.1
from R2 I can telnet R1,192.168.1.1 from R2, 192.168.128.1 and connection will be opened
and it will work ...
Thanks in advance
Tharak Abraham Tue, 11/29/2005 - 04:50
  • Bronze, 100 points or more
You can avail the above scenario provided you use the same addressing scheme throughout your network.
ie. it has to be in the same subnet.
