ATA and Faxing Issues
Nov 23rd, 2005
  • Silver, 250 points or more
Have some issues with a fax machines attached to Cisco ATAs (model = ATA186I2-A running OS 3.1.0 sccp), the devices cannot seem to transmit any number of pages sometimes. For example it will normally %80 of the time come up with a comm error, and the other %20 of the time it will send ok. Receive seems to be fine. I have enabled the ATAs for fax passthrough as per other discussions, and also on the H323 gateway, can anyone advise how to best troubleshoot this?
NB. connect mode set to 0x90000400 audio mode set to 0x00150015.
dial-peer voice 1 voip
incoming called-number .
destination-pattern 86..
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
voice-class codec 1000
voice-class h323 1
session target IPADDY
dtmf-relay h245-alphanumeric
fax-relay ecm disable
fax rate disable
no vad
dial-peer voice 90 pots
tone ringback alert-no-PI
translation-profile incoming drop
translation-profile outgoing prefix
destination-pattern 9T
progress_ind alert enable 8
direct-inward-dial
port 2/0:15
dial-peer voice 2 voip
preference 1
voice-class h323 1
fax rate disable
no vad
Just to add the fax machines have the numbers 8681-8684.
Any ideas?
LR
Overall Rating: 5 (1 ratings)
msolak Wed, 11/23/2005 - 15:00
hi,
you have a E1 controller, check the clock status.
if you have any alarms or failure on the controller the fax transmission will be unreliably.
1) check the controller (show contrlloer e1)
2) set the command: network-clock-participate slot 2
3) network-clock-select 1 e1
greetings
mehmet
dgahm Wed, 11/23/2005 - 15:23
  • Blue, 1500 points or more
Try adding fax protocol pass-through g711ulaw to your dial peers. Another thing to check is the mode used by the fax machines. ATAs only support passthrough at 14,400, so Super G3 fax machines, which use V34 up to 33,600 will fail. With some faxes you can explicitly configure G3 as the default mode, but in others you need to disable ECM which will turn off Super G3.
lee.reade Thu, 11/24/2005 - 07:30
After adding this command we have had no further issues, thanks for that!
Also, we have the same issues with an MGCP controller, the phones are at the same site as the ones before except their gateway to the PSTN is in the main site across the WAN, and thus via the H323 gateway mentioned earlier.
ccm-manager redundant-host x.x.x.x
ccm-manager mgcp
no ccm-manager fax protocol cisco
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
call-history-mib retain-timer 500
call-history-mib max-size 500
mgcp
mgcp call-agent x.x.x.x 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp timer nse-response t38 1000
mgcp sdp simple
mgcp fax t38 inhibit
mgcp fax t38 nsf 000000
mgcp fax t38 gateway force
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface FastEthernet0/1
mgcp bind media source-interface FastEthernet0/1
shoud I need to remove the 'mgcp fax t38 gateway force' even though t38 is disabled?
These faxes have different DNs, 75XX.
Any ideas?
LR
dgahm Thu, 11/24/2005 - 17:18
Your config looks OK, but try taking out the t38 gateway force, you definitely don't need it.
With a fax call in progress do a show call active voice brief and a show voice call summary. This will tell you if the fax is being handled as fax passthrough, or as a voice call.
Are all voice calls G711 across the WAN link?
runariversen Thu, 11/24/2005 - 04:11
I have had the same problem regarding fax on a ATA device and as msolak says, it may have to do with slips on the e1, this will not affect speech but definitly affect faxes.
example:
E1 0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20030902, FPGA: 11
Framing is CRC4, Line Code is HDB3, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 0.
Data in current interval (334 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
46 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
46 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 2 15 minute intervals):
0 Line Code Violations, 0 Path Code Violations,
256 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
256 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
But are you running a ccm or ccme ?
There are some issues with ATA sccp and fax on ccme not working at all, but i guess youre using ccm ?
br
Runar
