Issue with WLSE 2.12
Nov 24th, 2005
Since upgrading to WLSE 2.12 I've noticed that it's started doing a WLCCP authentication request via the WDS (AP-based) to our Cisco ACS 3.3.3 every 30 sconds without fail.
Is this a known bug or a new feature?
regards
Martyn
stschmidt Mon, 11/28/2005 - 09:50
  • Bronze, 100 points or more
Are you positive it is the WLSE that is doing the request? Can you do the below and attach the output.
Go to the WLSE command line via telnet or SSH, login as admin, and use the following command:
dumptcp proto ip interface ethernet0 host log
where is ip address of the WDS AP or ACS server which is the destination. Allow the capture to run for 1.5 minutes or so if the interval you are seeing is 30 sec. After that, go to Admin->Appliance in the GUI and download a copy of the dumptcp.cap file and attach it here.
Usually this interaction is initiated by the WDS device.
Thanks.
mgriffit Fri, 12/02/2005 - 02:07
Hi Stephen,
The main reason I believed it's the WLSE is becuase in the ACS logs it's the MAC address of the WLSE that is appearing in the "Caller-Id".
I've performed the tcpdump as requested and include the dump file.
best regards
Martyn
mgriffit Fri, 02/24/2006 - 00:38
I may have discovered what the problem is. On a recent posting (30 Jan 2006) called "WLSE WDS Authentication Issue" another user had problems with authentication of their WDS service. It would seem that I too may have been caught by bug CSCsb47726.
Because the authentication process is not quite working correctly, I suspect the WDS Access Point is trying to reauthenticate every 30 seconds to achieve "Security Keys Established" with the WLSE. At present it is only geting as far as "Authenticated".
This may also explain my problem with my WDS/WLSE/ Radio Management process not finding rogue access points since my recent upgrade to ACS 3.3.3 and WLSE 2.12.
I hope this helps others who may be in the same predicament.
regards
Martyn
Trending Topics - Security & Network
