Warning message
adignan Sun, 11/27/2005 - 20:47
  • Blue, 1500 points or more
Could you expound on this a little more?
Patrik Englund Tue, 11/29/2005 - 03:43
You can use the Call Redirect function if you have 2 scripts and 2 routepoints. Just make a If question and then point towards the Call Redirect variable and the call will be connected to the other route point where you have the Overflow script. The easiest way is to embedd the second script / CSQ into the first script and point towards that CSQ if for example the queue depth exceeds 3.
ciscoforum Tue, 11/29/2005 - 09:30
what if I just use one more select resource so that when it overflows it use the CSQ under this 2nd "select resource"? Then I don't need to use redirect.
