Warning message
SRST Config
Nov 25th, 2005
  • Community Spotlight Award,
    Member's Choice, May 2015
Anyone know if it's possible to configure hunt groups in SRST?
And if it is, is it possible to do it using a H323 gateway?
When in H323 mode, does any configuration hunt groups and so on cause other problems (like things matching dial-peers other than the ones that point to CallManager whilst in non-SRST mode)?
I'm thinking mainly of a site which (for example) has each phone with a DDI (no problem there), and a main number which would normally go to a CallManager hunt group or other queue... in SRST mode, is it possible to have a hunt group configured?
Aaron
p-kitaka Fri, 11/25/2005 - 13:01
I've achieved sequential hunt group functionality in SRST by using the alias command
call-manager-fallback
no huntstop
alias 1 7777 to 7701 preference 1
alias 2 7777 to 7702 preference 2
alias 3 7777 to 7703 preference 3
alias 4 7777 to 7704 preference 4
alias 5 7777 to 7705 preference 5 huntstop
-PMK
msolak Sat, 11/26/2005 - 05:30
  • Silver, 250 points or more
aaron,
virtuell numbers or hunt-groups (same as callmanager, with routing options such longest idle etc.) are not possible in srst, but you can configure alias or dialplan-pattern for numbers (pilotpoint etc) that can not fall in srst mode.
greetings
mehmet
