Warning message
IP Helper address on 6509
Nov 27th, 2005
I have 2 vlans(Vlan1 & Vlan305) on 6509
on vlan1 i have my dhcp server and i am trying my vlan305 network computers to get ip address from my server which is in vlan1
i configuried the following on my 6509
on my msfc
ip dhcp server 10.x.x.201
on vlan interface 305
ip helper-address 10.x.x.201
my users are not able to get IP. but if i use 6509 as dhcp server ist working fine.
is there any other configuration i need to do.
Sridhar
oj88 Sun, 11/27/2005 - 20:08
Can you provide a summary on how the DHCP server is configured.
What I've noticed is that, ip helper-address doesn't work when you configure a super scope in Win2k DHCP server.
amit-singh Sun, 11/27/2005 - 21:41
  • Blue, 1500 points or more
Sri,
The main point has be pointed out by the poster above. Just make sure that your inter-vlan routing is working fine and you are able to reach DHCP server from Vlan 305.Try to set up a static IP address on any one of the host in Vlan 305 and try to reach DHCP server.Its it works OK and you config is fine, somewhere the problem is in DHCP server.
Try to set different scope for each vlan and also try to use a different DHCP server.
regards,
-amit singh
glen.grant Mon, 11/28/2005 - 04:53
  • Purple, 4500 points or more
The one command "ip dhcp server 10.x.x.201" you don't even need if it is a standalone dhcp server , all you should need is the helper address on vlan 305 . This will forward all dhcp requests to that address . The problem is probably in your dhcp server setup if you can ping to the server from vlan 305.
