RME - Failed to get error string
Nov 28th, 2005
Constantly getting errror "Failed to get error string from logger 6203" whenever trying to retrieve Startup/Running out of sync report.
Context: RME > Configuration Mgmt > Startup/Running out of sync report.
Any one has ever encountered such a problem?
David Stanford Mon, 11/28/2005 - 13:41
  • Cisco Employee,
Has the default location of the config files changed from:
Windows: C:/PROGRA~1/CSCOpx/files/archive/config
Solaris: /var/adm/CSCOpx/files/archive/config
to some other directory or path?
If Solaris are the permissions ok on
They should be 750 on the directories in here and then the .cfg files these directories should be 640
Also, the owner of the files and directories should be user casuser with group casusers and not root
David
1lumkk Mon, 11/28/2005 - 20:23
I have checked & the files are still in the mentioned directory. Furthermore, i wasn't able to go to adminitration tab to change any value. Return the same error.
Context: RME > Administration > Configuration Mgmt > General Setup.
Regards.
