IP softphone versus Lotus Notes
Nov 29th, 2005
I have a problem with connecting to my Lotus Notes server relaese 5 when I'm connected with my VPN client version 4.0.
When I upgrade to version 4.6 or 4.7 my problems are solved. With version 4.6 or 4.6 the IP Softphone software (Avaya) doesn't work anymore. With version 4.0 IP softphone works normally.
Please help me out with this problem.
Kind regards,
Dirk Smit
The Netherlands
kleo Tue, 11/29/2005 - 10:38
  • Bronze, 100 points or more
In the Avaya ip softphone
Try the following: Go under
Settings > Login Settings> Advanced > "Check" Local IP Address and input IP address of VPN client "interface".
Do this after vpn tunnel is established.
see attached.
Dirks Tue, 11/29/2005 - 23:59
Thank you very much KLEO. We already tried this and that was not the solution to our problem.
Dirk
kleo Wed, 11/30/2005 - 09:25
kleo Wed, 11/30/2005 - 09:39
What version and Mode(RoadW,Telecom, etc) are you using the softphone in ?
Are you able to login ?
you might also try to disable QoS Packet Scheduler on the VPN Adpater.
