Warning message
X25 simultaneous call limit on Cisco router
Answered Question
Nov 29th, 2005
Hi all,
I have two cisco router with X.25 configured. When i start 10 X.25 outgoing call, the serial receive my 10 X.25 call :
-> 5 X.25 call are in P2 X.25 states which means these first 5 X.25 calls are transmitting.
-> 5 X.25 call are in D1 X.25 states which means these 5 X.25 calls are in hold queue and use flow-control.
SVC 11, State: P2, Interface: Serial1/1
SVC 12, State: P2, Interface: Serial1/1
SVC 13, State: P2, Interface: Serial1/1
SVC 14, State: P2, Interface: Serial1/1
SVC 15, State: P2, Interface: Serial1/1
SVC 16, State: D1, Interface: Serial1/1
SVC 17, State: D1, Interface: Serial1/1
SVC 18, State: D1, Interface: Serial1/1
SVC 19, State: D1, Interface: Serial1/1
SVC 20, State: D1, Interface: Serial1/1
How to modify this parameter to allows 10 or more simultaneous X.25 calls?
Correct Answer by Anonymous (not verified) about 11 years 8 months ago
you can use the "x25 hic/lic or hoc/loc" commands to set the number of virtual circuit ranges. check out the following link for the command references :
http://www.cisco.com/en/US/products/sw/iosswrel/ps1824/products_command_reference_chapter09186a0080087bb4.html#xtocid1212629
check the following link for X.25 Virtual Circuit States :
http://www.cisco.com/warp/public/133/x25_states.html
Correct Answer
Anonymous (not verified) Mon, 12/05/2005 - 09:54
