Cisco 2600 router -- Memory Question
This is an output of the show version command
2600>show version
cisco 2620 (MPC860) processor (revision 0x200) with
59392K/6144K bytes of memory.
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Now the router has 64MB of ram istalled
If I add up the two values it does not match 64mb
Can any one explain
cheers
per
Georg Pauwen Tue, 11/29/2005 - 14:27
  • Purple, 4500 points or more
  • Cisco Designated VIP,
    2017 WAN
Hello Per,
you are right about the numbers, the values are actually calculated as following:
58 x 1024 = 59392
6 x 1024 = 6144
Total: 65536
So actually 6MB is 6144K, and 58MB is 59392K...
HTH,
GP
