11-29-2005 04:13 PM
Good Day All,
I have a Cache Engine 550 here and the transaction log working.log file got quite large.
I was not able to export it to my ftp server so I logged into the Cache engine via ftp and downloaded the file to a PC.
I then deleted the working.log file on the Cache Engine and rebooted the cache engine.
The working.log file was not re-created as I had hoped it might be.
I have created a file called working.log in the correct directory. This file does not seem to get updated though so this must not be right either.
Any suggestions?
regards,
amanda
11-29-2005 09:08 PM
Amanda,
What version of ACNS are you running? Can you please try disabling and re-enabling transaction-logging?
Can you post the output of the command 'show transaction-logging'?
regards,
~Zach
11-30-2005 01:50 AM
Hi Zach,
Thank you so much for writing back. I am running an archaic version of the software... i can check tomorrow. As to the logging.... i had not enabled transaction-logging in itself so it was a silly config error ...
:) amanda
