CCMv4.1(3) LDAP attribute
Any idea of what CiscoCCNatAAPromptName and ciscoCCNatAAKeyPadMapping do in the cisco schema for CCM LDAP integration? Believe they are being used in CCM v3.3 only.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801d3c48.shtml
Searching on CCO and only found this for CCM v4.1 LDAP cisco scheme and attributes.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_administration_guide_chapter09186a00803edaa5.html
Question is what are the definition of ciscoCCNatAAPromptName and ciscoCCNatAAKeyPadMapping? And are they being used in CCM v4.1? A list of cisco attributes which will be used for CCM v4.1 – LDAP integration will be helpful. Thank you.
gogasca Tue, 11/29/2005 - 23:11
  • Green, 3000 points or more
Hi Tom
Those attributes are part of the user profile and are used for different applications for example AA.
ciscoCCNatAAPromptName "gogasca"
ciscoCCNatAAKeyPadMapping "4642722"
Look at the schema LDIF files to see the updates that
CallManager does. The files can be found in:
C:\dcdsrvr\run\dcx500\config\AD
at_schema.ldif
oc_schema.ldif
Because the schema might change with every major Cisco CallManager release, you should run the Cisco Customer Directory Integration plugin after every upgrade.
Gonzalo
