Warning message
Network Packet Monitoring tool
Nov 29th, 2005
HI
I have 50 client pc, cisco switch and router. often i face a problem that is large packet generate. manullay i find out which pc generate exceed number of packet. its boring job.
I am looking a best packet monitoring software. by the software i can find out every pc generate type of packet, number of packet and whats reason packet generate .for which reason workstation/pc generate packet.
IF I install the software in my monitoring pc then i can get all information from the workstation pc or any configturation in gateway Cisco switch ? for monitoring.
pls give me the information about the software who are used and get benefit.
thanks
Biplob
Overall Rating: 5 (1 ratings)
thisisshanky Wed, 11/30/2005 - 21:09
  • Purple, 4500 points or more
In addition to what Edwin and Rick suggested, "IP route-cache flow" on the interfaces of the router which enables Netflow, to figure out top talkers, as well as protocol level stats (you will need a hex to dec converting calculator, windows calc will do).
If you are looking for a "Nice but Xpensive" solution you can get modules such as NAM (for 6509) and NM-NAM for the routers, which has a built in packet capture tool and an embedded web interface to display the captured output..
PS: Please remember to rate replies!
Georg Pauwen Wed, 11/30/2005 - 05:14
  • Cisco Designated VIP,
    2017 WAN
in addition to Edwin´s post, you might want to start out with enabling ´ip accounting´ on your router interfaces. The output will give you source and destination IP address pairs, as well as the number of packets and bytes.
Also, there is a free sniffer available that might be useful, you can download it at:
www.ethereal.com
HTH,
GP
iqbalkhan Sat, 12/03/2005 - 21:25
Thanks to all. For this software any configure in switch like configure monitor port enable ?
Thanks biplob
desai.jaideep Sun, 12/04/2005 - 22:39
  • Gold, 750 points or more
No need.These software will monitor all the packets roaming in ur LAN.
PS:-Even the spanning tree packets and CDP packets will be visible.
JD
iqbalkhan Mon, 12/05/2005 - 00:00
thanks but my question is my pc where install the software , the network cable connect any port of a switch, then i get all information from the network where pc are connect the switch ?
or connect the monitor port of gateway switch.
thanks
biplob
desai.jaideep Mon, 12/05/2005 - 00:09
I am not able to understand what a "Gateway switch" is?Probably give the model no.
The software will listen to the packets in your typically what you call a broadcasting domain.Hence the PC should be connected to a normal port, just like other PCs in your network so that you would be able to "sniff" the packets.Try installing in your workstation PC.
JD
iqbalkhan Wed, 12/07/2005 - 00:01
Its a excellent helpful software.i already insatalled and observation it. its provide me which I want.
but i have some question:
it has option
1. protocol, decode, connection, statistics and capture filter.
in protocol option i found 1.frame and ethernet.
i run the software 5 min and shows ethernet 98%.
This protocol and statistic option shows overall network statistic or my pc lancard statistic ?
2. In connection option dispaly always realtime log ?
3.when percantage 100% then capture stop or freeze and when i again start then it work so for 30 min or 1 hour continious observation what i configure ?
for best benefit from this software any suzzation from you in configure level ?.
Biplob
desai.jaideep Wed, 12/07/2005 - 06:47
Ques 1--> It is overall network statics for your network
Ques 2-->In connection window,the log is always based on the capture.You may refer it as realtime until you are capturing.
Ques 3-->To tell u the truth, I never tried to do 100% capture,b'coz my problems are solved before that,but try maximizing the capture size.The default settings are best suited.
PS:Monitor the decode window, thats where the action is.
JD
