Adding vlans to existing trunk on 6500
Answered Question
Nov 30th, 2005
Can someone confirm let me know the following :-
1) What is the command to add vlans to an existing trunk on a 6500 series .. its using CatOS.
Here is the trunk being used.
clear trunk 2/5 1-81,83-100,106-111,114-119,122-124,127-139,141-1005
set trunk 2/5 on dot1q 82,101-105,112-113,120-121,125-126,140,1025-4094
I would like to add these vlans in :-
1) 161 - 168,
2) 650 -701
2) There would be no downtime to do this change right ?
Thank you,
-SN-
Correct Answer by glen.grant about 11 years 5 months ago
"set trunk 2/5 on dot1q 161-168,650-701 " . No downtime. If running client/server you add this on the server , if running transparent then you have to do this on both sides.
Overall Rating: 5 (1 ratings)
Correct Answer
glen.grant Wed, 11/30/2005 - 04:42
  • Purple, 4500 points or more
sanjaynadarajah Sun, 12/11/2005 - 01:24
If this port 2/5 is channeled with port 2/6, then I would need to add the command as follow to both end of the switch right ?
set trunk 2/5-6 on dot1q 161-168,650-701
If I configure as :-
what would happen ? Would the channel fail in this instance ?
Please advice,
Thank you,
-SN-
