Video over MLPPP connection QOS question
Answered Question
Nov 30th, 2005
I'm setting up a dual-T1 MLPPP connection between two sites and want to run video conderencing over the link.
Here is the config in the 2621 router at the remote site:
class-map match-any Call-Control
match ip dscp cs3
match ip dscp af31
class-map match-any Video
match ip dscp af41
class-map match-any Voice
match ip dscp ef
policy-map Wan_edge_mlppp_BRN
class Voice
priority percent 22
class Video
bandwidth percent 15
class Call-Control
bandwidth percent 5
class class-default
fair-queue
random-detect
interface Multilink1
ip address xxx.xx.xxx.xxx 255.255.255.252
ip route-cache flow
ppp multilink
ppp multilink fragment delay 20
ppp multilink interleave
ppp multilink group 1
max-reserved-bandwidth 95
service-policy output Wan_edge_mlppp_BRN
interface Serial0/0
bandwidth 1536
no ip address
encapsulation ppp
ip route-cache flow
no ip mroute-cache
no fair-queue
service-module t1 timeslots 1-24
ppp multilink
interface Serial0/1
bandwidth 1536
no ip address
encapsulation ppp
ip route-cache flow
no ip mroute-cache
no fair-queue
ppp multilink
My question is - should I have the 'ppp multilink fragment delay 20' statement in the mlppp config? Does it matter whether there is fragmentation when trasporting video (or VoIP for that matter0?
Correct Answer by spremkumar about 11 years 8 months ago
Usually fragment delay is being used in for the realtime traffic mostly for ur voip traffic coz it may have deep impact on time it taks in placing the packets on the wire.
I had seen the command keyed in under the config in the recent past mostly for the voip traffic and but not sure of the impact witht the video traffic..
if ur interested and can afford to have testrun u can check with and without the delay command over ther in the configs ..
regds
Overall Rating: 5 (1 ratings)
Correct Answer
spremkumar Wed, 11/30/2005 - 22:57
  • Red, 2250 points or more
regds
