Warning message
Can two pix interfaces(outside) implement load balance.
Nov 30th, 2005
My pix has three interfaces.one is used to inside interface .The others(two) are used outside interfaces.the two outside interfaces can implement load balance.
How can I do. thanks!
jackko Thu, 12/01/2005 - 04:10
  • Gold, 750 points or more
pix is not designed to perform advanced routing function, such as load balancing.
spremkumar Thu, 12/01/2005 - 04:44
  • Red, 2250 points or more
In addition to Kos comments like to add few lines which can be useuful if you are intersted in thinking off some real solution for load balacing..
you can have a router instead in front of the PIX which can very well take care of the load balancing.
ofcourse you can have something like BGP configured in ur router and do the advertisements as well as the reduandcy taken care by that..
regds
