number hiding on a ccme 3.3
Hi, does anyone know how to change the calling number that appears on a fxo port attached to a box with a celular card?.
This is often used to route calls to celular phones.
Example, you're using a dial-peer to route all calls to mobile phones, and you're using an fxo line connected to a box with a celular phone card with number 606345567, I want to hide this number and let the called party see 902134567, just to hide the celular numer.
Thanks a lot.
thomas.chen Fri, 12/09/2005 - 06:49
  • Silver, 250 points or more
Add the "dialplan-pattern" that will work with your dial plan. This will allow the called numbers to see the full E164 number.
