Warning message
pradeepde Thu, 12/08/2005 - 07:19
  • Bronze, 100 points or more
You can use RJ-48 T1/E1 straighet-through NM-CEM-4TE1 to connect 75-ohm ohm unbalanced
E1 network.
In general all serial interface types except EIA-530 are available in DTE or DCE format: DTE with a plug connector at the network end and DCE with a
receptacle at the network end. V.35 is available in either mode with either gender at the network end. EIA-530 is available in DTE only."
This URL speaks about NM-CEM-4TE1:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios123/123newft/123t/123t_7/bbfeamod.htm
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cg/hif_c/ch10/hbbfeamo.htm
http://www.cisco.rw/application/pdf/en/us/guest/products/ps2797/c2001/ccmigration_09186a00800e772f.pdf
