3825 Doesn't boot
Dec 2nd, 2005
I'm receiving this on a 3825:
program load complete, entry point: 0x8000f000, size: 0xc0c0
Initializing ATA monitor library.......
loadprog: error - on read during ELF program load
requested 27157520 (0x19e6410) bytes, got 16748852 (0xff9134)
open: failed to find and/or load the bootloader: "flash:c3825-spservicesk9-mz.123-11.T8.bin"
loadprog: error - on file open
boot: cannot load "c3825-spservicesk9-mz.123-11.T8.bin"
System Bootstrap, Version 12.3(11r)T1, RELEASE SOFTWARE (fc1)
Copyright (c) 2004 by cisco Systems, Inc.
System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
Total memory size = 256 MB - DIMM0 = 256 MB, DIMM1 = 0 MB
c3825 processor with 262144 Kbytes of main memory
Main memory is configured to 72/0(dimm 0/1) bit mode with ECC enabled
Upgrade ROMMON initialized
boot: cannot load "flash:"
rommon 1 >
thisisshanky Sat, 12/03/2005 - 10:02
  • Purple, 4500 points or more
You should be able to use the CF slot on 3825 , copy an image into the CF card and boot from it from rommon.
