Warning message
IPX over DMVPN Tunnel
Dec 5th, 2005
I currently have three sites that running DMVPN tunnel with Ip eigrp routing enabled. Is that possible to turn on IPX routing over this DMVPN tunnel to route IPX over the VPN.
Thanks in advance
gfullage Mon, 12/05/2005 - 18:15
  • Cisco Employee,
IPX over DMVPN will not work unfortunately. It's not so much DMVPN, but the fact we removed IPX from the NHRP code some time ago (back in 12.2 IIRC), and DMVPN uses NHRP to find its next hop. It works for IP as you know, but there's nothing in NHRP anymore for IPX.
