Router 1721, CME, IPPHONE, which wic? for pots connection
Dec 6th, 2005
I have a 1721 router with no WIC interface yet.
I would like to have IPPHONES on the LAN but only one connection to the POTS.
If I buy:
1 WIC-ADSL for Internet access and
1 WIC for Pots connexion.
Will it be sufficient?
And which WIC should I buy for POTS access?
Many thanks.
Gael
spremkumar Tue, 12/06/2005 - 05:13
  • Red, 2250 points or more
I feel u need to check something inline with VIC-2FXS interface card which can get u connected directly to the POTS.
do refer this link about the compatability and the specifics of the same..
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a0080094fac.shtml
if u r talking about interfacing EPABX then i would suggest for an E&M card instead of FXS.
regds
